FRONT ANTI ROLL BAR MOUNTING
Danny wood
Essex
Hi All
Have replaced all the bushings on the front for Power flex Bushings except the FRONT ANTI ROLL BAR MOUNTING. I just jacked the car up knowing i needed to measure it had the VERNIER on it coming up 24.5 do i get the 24mm ones and squeeze them on or 25mm i would probably order the 25mm if left to my own devices but just thought i would check Incase you want/need them tight tight
Cheers Dan
Did you measure the roll bar where the original bushes have been wearing Dan? A slightly tighter fit is better than slightly loose in my opinion.
I would go with 24mm personally.
Danny wood
Essex
measured in several places but might have another go tomorrow night .when. i came back to the pc to order i was expecting bigger gaps in the sizes not 1mm increments cheers for your input
dan
mrscalex
Swindon & Swansea
On a 2.2/3 litre it's 25mm non-Sport and 25.5mm Sport. And I coincidentally checked the other day and thought Powerflex covered all sizes? Unless you have the wrong ARB on there you maybe mis-measuring and it's 25mm.
There is possibly a 24.5mm ARB, possibly from a pre-facelift.
