Fuel gauge
Medskipper
Z3M & Z3 1.9.
my 2000 Z3M fuel gauge is not reading correctly, it is working but even when the tank is absolutely full it only read three quarters full.
I’m guessing I might need a new sender? But is there another reason this might happen?
thanks guys
Althulas
Banburyshire
M Roadster
You could try activating the cluster test mode to see if the gauge will move through it’s full range of movement if it doesn’t most likely the sender unit faulty. I’ve seen suggested trying a fuel cleaner full out anything making it stick. Link for testing http://forums.bimmerforums.com/foru...de-Hidden-Codes-in-your-car!&highlight=hidden
There is an existing thread on .net where some Dutch guys got a part manufactured and is available on eBay using the item number in the thread. https://www.zroadster.net/forum/viewtopic.php?t=43604
