Great result.
Bozzy
Long Eaton.
These had been collecting dust in the garage for about 4 weeks, so as the weather
was decent today I summoned up the courage to have a go at fitting them.
They looked absolutely fine but @t-tony showed me how much the front wheels flexed and apparently It's down to worn control arm bushes,at the rear of the arm.
I was surprised how bad they were when I was able to easily separate the mounting from the rubber inner.
I watched some clips on line on how to change them and some people opted to burn the rubber out with a blow lamp,some people used lump hammers and chisels. I didn't need to do either :D.
Once the bracket is off you're left with the rubber inner stuck on the control arm. I used a multi tool to cut through it with ease,it has a metal sleeve on it also but once a cut is made it seperates and slides off.
Then the metal collar has be removed from the inside of the bracket,I used a hacksaw to cut a slot across it and then used a hammer and chisel to ease it out.
A quick run round with some abrasive strip before popping in the new bush.
Then on to the car
The instructions supplied with the kit are very good and clear,even to a pleb like me :rolleyes:.
A good coating of the supplied silicon grease on the black bit and inside the purple bit to aid the fitting and prevent any squeaky noises when driving.....
and Bob's your uncle :D.
Thought I'd struggle to do this on my own and Tony did very kindly offer his services but luckily mission complete.
Went out for a little test drive for an hour and I'm so pleased I replaced them old bushes as the car didn't corner too well before. Didn't realise how bad it was until @Nodzed let me have a drive in his fab //M,my zed felt awful in comparison :(.
BUT NOW it feels bloody ace in the corners as the front is instantly grippy and doesn't drift wide,making the rear more responsive.
I know it's an old cliche but it feels like it's transformed the car,so a job well worth doing :).
Steve.
Top job mate, well done.
Jjim
Mansfield
1.9 Roadster
Job well done :thumbsup:
Think I need to look at mine at some point.
Bozzy
Long Eaton.
Thanks Tony, another job that I wouldn't have tackled without some of hints and tips picked up at the zed shed midlands :).
I'm back in love with my zed again now :D.........might even nip out for a night time,roof down blast =)).
Nice one pal, well done, tightens the full front end, :thumbsup:
2.2 & 3.0 Sport
Top job Steve, good man for having a go.:thumbsup: We'll have to try it out in the Peaks sometime:whistle:
Same at Tanvic Tyres Mick, but a long way for you. . . . . . ;)=))
I think in all, it took 2 hours to do both sides Jim. The bushes cost about £46 from eBay.
That'll do, you can come over and do mine :thumbsup:=))=))=))
Bozzy
Long Eaton.
Probably a good idea to have the alignment checked now, took mine to the local ATS and it seems they don't charge if they don't actually have to adjust it. Hurrah.
Yes I agree and I'll try A.T.S as you say,if it doesn't need adjustment, no charge. Had it checked and adjusted a few months ago before I knew the bushes needed replacing. Funny thing is, I asked them if anything needed replacing on the steering/suspension and they said no :meh:. Not A.T.S though.
Bozzy
Long Eaton.
Thanks Dave :). Funny enough I've just concocted a route on tyre that will need trialling :coolsteer).
Bozzy
Long Eaton.
Count us in as mine also needs a thorough test :D:thumbsup:
You ok to come over this way Sean ? Or are you going to show us some of those lovely roads around your neck of the woods ?
We're out with the Mints in a couple of weeks all being well, so we can all have a steady little pootle :whistle:.
