Rand Soper
I have a question or two about the parking brake adjustment. I have read the instructions but one or two things aren't clear to me. When you press in the spring/retainer and clip the hooked bit on the end of the cable over the ridge on the retainer, should the hand brake lever be lowered or raised?
Also, when everything is adjusted correctly there should be quite a bit of tension on the handbrake lever when pulling it up, correct?
I just bought my first 4 wheel BMW, a 2008 3.0Si (I have had a few 2/3 wheel BMW's in my life, my favorite was a '66 R60 w/sidecar. Should never have sold that one) and there are only two things wrong with it, the parking brake needs adjustment and the passenger door power door lock locks but doesn't unlock. It tries but no love. I have a new door lock solenoid and will get that replaced ASAP.
Thanks so much in advance for any assistance!
