Hand held bleeder.
This arrived I n the post today. A vacuum brake bleeder and fluid mover.
You simply connect an airline to the valve and the tube to the port on top of the bottle. Attach the tube to the bleed screw and loosen, then open the tap and as the air flows through it sucks the fluid from the bleed screw.
Just the same as the fluid remover highlighted by @Andy McDonnell a couple of weeks ago. The one Andy showed does have a hand pump to create vacuum too for those who don't have a compressor. For £13 I thought it was worth a punt.
Is there any advatage over a pressure bleeder mate, I've still not got a pedal, but the brakes lock when full on
Bozzy
Long Eaton.
That looks a lot easier to use than the old pressure bleeder, no pumping up required :thumbsup:.
andyglym
Cheeky little gadget mate, as you say, only £13 :thumbsup:
Tell you when I've tried it chaps.
Jamezee
Peak District
Similar to what embalmers use :eek:
2.2 & 3.0 Sport
Looks a handy bit of kit Tony:thumbsup:
I hope it turns out to be Dave, mind you when you read the instructions I'm really glad I already know how to use one ...............................
All clear now?
2.2 & 3.0 Sport
I'll tell you soon Sean. Might try it at work.
Not likely, if I'm doing a job for them I get paid mate.:thumbsup:
handsomejackuk
Australian Zeds
t
yeah be good to see how this works looks like an easy thing to make too... assume its using the compressor and creating a vacuum through a venturi somehow... its got to be easier than getting someone to pump the brake pedal while bleeding... has anyone thought about using a garden pressure sprayer to create a vacuum somehow....?
anyone used a mightyvac ?
FRANKIE
Looks kinky..............does it have any other applications???????....................Frankie
Only limited by imagination I would guess Frankie. =))=))
Understood - looks a good tool and not expensive. Thanks
JC
I did have it hooked up to an airline at work and it seemed to have a decent suction on the vacuum side at w/shop pressure.
