@t-tony Your excellent article on replacing handbrake cables (it's what google points to!)
https://zroadster.org/articles/bmw-z3-parking-brake-cable-replacement.80/
I just can't budge the cable from the back of the hub.
Coming at it from a different angle - Once the handbrake pads are removed there's that bracket-like thing. No. 5 in this image
Is that the tube that the handbrake sleeve is stuck in? The bolts holding that onto the hub were easy to loosen so would some wiggle (heat?) on that bracket help to release the cable?
