Hardtops
Johnnywheelnut
Suffolk
Are all Z3 hardtops the same will a 98 one fit a 2001 the 2001 car has roll hoops what parts do I need for fitting ? thanks
You need a fitting kit which will cost circa £300.
Mainly the 2 side mounting from just behind the seats. Best to search Z3 hard top and see. Maybe even look on YouTube for videos.
Jack Ratt
The West Country
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
Check your car, they might already be fitted
Jjim
Mansfield
1.9 Roadster
BMW Z3 hardtop fitting kit should include:
  • Mounting bracket LEFT with 3 fitting bolts - items 4, 5 & 6
  • Mounting bracket RIGHT with 3 fitting bolts - items 4, 5 & 6
  • Plastic mount cover LEFT with sliding cover cap with 1 hex fixing screw - items 25 & 35
  • Plastic mount cover RIGHT with sliding cover cap with 1 hex fixing screw - items 25 & 35
Note - I haven’t shown part numbers for these as they are no longer available from BMW
  • Wiring harness for hardtop - located on passenger side mount (UK) - item 4
Note - The hardness is connected to the mounting bracket and fits between 2 existing wire connectors that are located under the carpet trim next to the roof bracket joint behind the passenger seat.
  • Rear screen demister switch for hardtop glass screen. If your car is prefacelift (1996 - 1999) it will be picture 1 or if it’s facelift (1999 - 2002) it will be picture 2
PICTURE 1
PICTURE 2
Hope this of some use.
