Hi all
I know it’s probably been covered some where on the forum before. The question is I have a miss fire on start up from cold only by cold I mean over night or right through the day at work I’d say it is only one cylinder and the miss fire only last for around 15 to 20 seconds clears and then runs perfect. When warm car starts as normal and runs well.
I was told that the M44 engine dose not like the 4 pronged long life spark plugs that I put in it after I gave it its first service when I got her, so I decided to go back to the O.M. E Bosch plugs this has made no difference. The plugs I took out are perfect in every way burn wise light grey to brow. I’ve also been told it could be H.T leads but a set of these are not cheap and I’m reluctant to start changing things that are not the cause of the problem. It’s not showing any fault codes so I’m at a loss. Dose any one have any suggestions.
