Hi All. Wondered if anybody has had similar fault. When driving with the headlights on dip beam and I operate the indicator switch to turn right the main beam comes on as if the switch is being pushed away from the driver. all other functions are fine, ie left turn indicator operation all as it should be, if headlights are not on again all is fine.
I guess I will have to fit a new switch.
Thanks in advance for any help
