Hello from Dorset -new member
David Solloway
Weymouth, Dorset
Hi Guys
Just joined the group looking to buy a z3 in the coming few weeks once my tr6 is sold. I’m looking forward to the driving experience of a more modern roadster with some real power.
where is the best place to buy, any recommendations.
cheers David
Mus Musculus
Ramsey, Huntingdonshire
Welcome from Cambridgeshire. :welcome:
I would say the best place to buy a Z3 is right here. Be patient, and the cars will show up in here, owned by enthusiasts, which is the best kind of correct… ;)
It’s a 1.9 (M43 Engine)
If you are new to Z3s take a look at this thread..pretty much everything you should look for.
‘There’s nothing more expensive than a cheap Z3’ 😁
2.2 & 3.0 Sport
Hi David and :welcome: to the forum from another Dave in Stafford. I drive my 2.2 most of the time, so I have a 3.0 Sport in the garage which may suit you.
2.2 & 3.0 Sport
I have a 3.0l and the 1.9l.. both ends of the spectrum. I would seriously try and drive all engines as they are quite different. I would also not discount the 1.9s. Much lighter feel than the 6 cylinders and out of the two I have it is by far the more engaging. 2.2 and later 3.0 are Ulez compliant if that is a concern. I would also buy based on condition and maintenance, not mileage.
:welcome:
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
colb
Newport, South Wales,UK
Welcome aboard the Forum, you have arrived at the best Z Forum on the Web, help and advice always available here.
As our membership is Worldwide its a good idea to update your user details with your location and model of your car, it assists us in answering your questions.
You could also add a signature to show these detail so they appear in all your future posts.
If you are lucky you might be close to one of the enthusiast run Zed Sheds where members meet up and do jobs on each others cars.
If your new to OBD2 you will want to bolster your toolbox with a decent Code Scanner, bound to need one sooner or later.
I can reccomend a Creator 310+ as a good all round scanner and easy to use.
If you want to go the Laptop route then find yourself a Windows laptop running Windows 7 or above and
purchase BMW Scanner 1.4 available on ebay for little cost, it comes with its Interface, cable and software on a usb stick, you will need a 16pin to 20 pin cable changer to plug
these diagnostics in to the under bonnet diagnostic plug (Pac-man socket) to read all modules on the car.
If yours has a 16pin obd2 socket under the steering wheel inside the car that will only read the engine and transmission modules,
the Pac-man socket reads all modules. If you get hooked on Diagnostics you may want to have a go with BMW software, INPA, NCS Expert, Winkpf and DIS, these
can be problematic setting up but usually due to configering the right drive and usb settings. Help usually forthcomming on the Forum if you run into install problems.
colb
Go to top right of page where your user name is click on there to access settings you can update settings there
