Help! Lean codes and idle stalling issues
JP701
Hi All,
I have a U.K. Z3 2001 2.2i M54 engine.
I’ve had for a long time lean codes (both banks) popping up on random occasions for a few years now. Some things were done including, smoke test/CCV change/O2 sensors checked/Fuel pressure check/MAF sensor checked.
Recently been having issues with starting (taking a while to crank) and low idle stalling and jerky throttle control. Occasional throw up of the camshaft sensor fault but I’m getting confused if all this is still caused by the initial lean symptom.
I can send a video of me revving the engine from idle to a little over 1000rpm. Sometimes it will drop to a lower rpm pushing the throttle and sometimes as it falls back to idle it dips below and can stall.
Any info or suggestions hugely appreciated!
Ianmc
New Forest
Z3 (M44)
The symptoms you describe, in addition to the camshaft sensor fault, seem to indicate such.
Can I send you a video of the engine running? Is that possible on here..?
[/QUOTE
You can't upload video directly to this forum. You need to upload it on YouTube (or similar) then post a link to the YouTube video on here.
colb
Newport, South Wales,UK
Long crank is certainly a symptom of a bad camshaft sensor, as you have already seen a code for this best replace it with an oem sensor do not use cheap pattern parts.
