It is an ABS fault code, it suggests that their is an issue in the circuit, which could be the wiring, a sensor, fuse, relay or ECU Controller. You need to methodically test the system to identify which of the above is at fault. Obviously a fuse is the cheapest and an ECU the dearest, so would check / test in that order.
