help needed
katkwak
Hucknall / Nottinham
1.9 m44
car as just failed on 3 things any advice please
1 engine management light not working new to Mot test
2 air bag light on 3 front
3 imbalance in front brakes might just want cleaning up
Davyhoogy
Sunderland
'98 2.8 z3
1. This could just be a bulb? Swap a bulb from another indicator and see if it then lights up. Instrument cluster is easy to take out.
2. Airbag reset tool, if you can't borrow one they are cheap on eBay. That will at least clear the fault, if there is a further issue it will light up again. Check plugs under seats.
3. Is it an imbalance in braking effectiveness? Maybe try bleeding the brakes, if that doesn't help you may have a sticky piston.
