Hi,
With the interior of my M removed I can easily see if there are any issues with water entry into the cabin. Over the last few days it has rained a lot and today I have found a puddle un the cabin under where the drivers seat would be.
I know that normally water enters the channel at the top of the windscreen and goes down the hole in the top corner of the windscreen / A pillar and then runs down the back of the rubber seal, passed the join in the seal (where I am having the water issue) and then down and out at the bottom of that rubber and away down the outer sill.
A quick test looks like the water is entering into the inside of the door at the join area of that seal by the door jam where the bottom of the qtr light window is.
What I can't see is whether the issue is with the area where the seal join is - there is a little gap which is different to the passenger side or whether the passage of water behind the A pillar is blocked and therefore instead of water disappearing down the hole in the top corner it is instead forcing the water over the top and down the outside of the seal and then down into the cabin somehow.
In order to eliminate the drain being blocked I am wondering how you can clear this drain?
