Help with this part please
raymond
EAST SUSSEX
Z3M
Spending a lovely morning on my back, not that sort of morning, busy removing my rear wing. A few problems along the way but I am taking many pictures and hope to post a thread on it soon. However there is this "sensor" which is situation inside the rear wing just under the filler cap. The bracket is rotten so I will need to find a new one but can anyone tell me what this part is for?
I believe this is the outside temp sensor, the brackets are prone to rusting and new ones are eye wateringly expensive IIRC. Just make a bracket and mount it again.
@Mnbrennan had a pic of this on his car, a cable P clip did the job well
raymond
EAST SUSSEX
Z3M
Thanks for the picture. Sensor was damaged so need a new one. Anyway will use a p clip as advised to save £12 for the bracket
Mnbrennan
Aylesbury
BMW M Coupe / 2.8 roadster
Yeah that was done prior to my ownership, hold it fine just there
Strange placement for an outside temp. sensor. Commonly they're mounted in (usually) the door mirror casing or front bumper.
Yep, for some reason on the ///M it was in the rear! I wonder if they were worried about residual heat off the engine bay?
Only reason I could think of Brian. Is the Z4M there too?
ps. Just thought, at ZedFest this year you'll be in the Z4 field, must come and have a sit in yours. You never know I might end up with an ///M next year myself.=))
PHILIP BAXTER
Cardiff
Z3 3.0i Roadster
ps. Just thought, at ZedFest this year you'll be in the Z4 field, must come and have a sit in yours. You never know I might end up with an ///M next year myself.=))[/QUOTE]
This could be a photo opportunity.
Who will win the race to get in first, @t-tony or @BMBabe? :whistle::whistle::whistle:
No contest Phil.:(
Tally Ho
I have a 2000 Z3M. I don't see any "outside temperature" gauge anywhere.
Does this year Z3M have that?
Greg
Ianmc
New Forest
Z3 (M44)
UK market ones do, perhaps different in the US?
Chazzy
Northampton
I found the sensor had completely failed, and they are 100 quid to replace. I found a cheap temp sensor but it's the wrong voltage range. If anyone knows a cheap alternative I'd love to know!
raymond
EAST SUSSEX
Z3M
I have ordered something from Ebay. It was £20 but I am not sure if it will either fit or work. They take returns so it is worth a try. Have tried to source V.D.O sensors but no luck. As usual with an M there is always something different and expensive with them !
