Help with warning lights
UCop303
Hi all! I’m new here and recently bought a 2002 Z3 Roadster 2.5. The DSC and Brake light were popping up periodically and then disappearing on and off for the last couple of weeks, but now for the past few days they won’t clear. Brake fluid is good but I also think that has its own warning light. I don’t have a users manual and online searching for this hasn’t really helped. Has anyone had this issue or have any ideas?
Stevo7682
Maybole , South Ayrshire
You really need to get it plugged in to a diagnostic tool as there is a number of things could be creating the fault.
You have 4 abs wheel sensors ( and associated wiring)
2 pressure sensors on master cylinder
Abs pump unit
Yaw sensors under passengers seat ( will fail if roof leaking and water getting under carpets.
So next step is to get fault codes read see whats creating it (even if lights go out fault still stored in memory untill interrogated and cleared.
Stephen.
UCop303
Abs pump unit
Stephen.
Thank you. Scanner used in the port near passenger footwell didn’t show any codes. I’ll look into 20 pin port with name scanner that another member recommended.
Stevo7682
Yes the under dash obd doesn't give much access.
The 20 pin under bonnet is the nain point of access.
16 to 20 pin obd adapter plenty available on Ebay and the likes.
Once codes read that will take you straight to the problem.
Stephen.
UCop303
Stephen.
I’ll get the adapter
Stephen.
[/QUOTE
Perfect. I’ll order the adapter today. Thank you
Pond
Spaldingski, Lincs
Z3 project
Just hope it's not either (or both) yaw sensors under the carpet. They are very expensive. Ask me how I know.
UCop303
I just researched that and looks like it’ll be about $1k each installed. Fingers crossed that’s not it. New BMW scanner and 20 pin adapter will be here on Saturday.
John_B
Derbyshire, UK
Z3 2.8 pre-facelift (Izzy)
Check your brake fluid level. I had these lights would flicker on and off ocassionally. Turned out that the fluid was right on the minimum.
UCop303
That was the first thing I checked. It’s clean and right at the proper level. I was hopeful lol
nick282
In cases where warning lights appear on the dashboard, it’s important to communicate clearly with mechanics or support teams by sharing diagnostic reports and service documents. A fax from iphone app can be an efficient tool for sending such information directly from a smartphone, eliminating the need for a physical fax machine. The site https://comfax.com/reviews/top-iphone-fax-apps/ provides detailed reviews of the top iPhone fax apps, helping users find reliable and user-friendly options for faxing important documents. Using one of these apps allows vehicle owners to quickly transmit repair orders, diagnostic results, or warranty paperwork to service providers, facilitating faster and more efficient service. This digital approach not only saves time but also ensures that communication remains clear and documented, which is crucial when dealing with vehicle issues like warning lights.
Thanks for information!
