How To Guide How to build your own BMW Z3 Sub Woofer Box
Susan
Central Coast
Sub box
What you will need
  • 5mm MDF board
  • 15mm MDF board (for Sub ring)
  • 20mm think EVA Foam
  • Small screws
  • Wood glue
  • Silicone sealant
  • 10mm thick Wood (for support blocks)
  • Sub carpet
  • Speaker terminal cup
  • Spray glue
  • Leather or weather proof Vinyl
Tools you’ll need
  • Jigsaw
  • Screwdriver
  • Drill and drill bits to pre drill holes
  • Pen or pencil
  • Sandpaper
  • Staple gun and staples
  • Hacksaw blade (for cutting foam)
Cut all pieces and pre drill all holes.
Cut out the shape of the Speaker terminal cup in the back of “A”.
Screw 2 “H” support blocks to “B” (Fig 1)
Screw “A” “C” and “D” to the “H” support blocks (Fig2)
Screw “D” “E” & “F” to support blocks “I” to top and bottom (Fig 3)
Screw in support blocks “J” (Fig4)
Screw Support block “K” into top leaving a 5mm gap at the back and side.
Turn top over and screw Sub ring to top of Sub top.
With a hacksaw cut the foam to cover around the sub ring.
Then cover it in leather or Vinyl and staple down the edges.
Fit the top on and screw into “K” on both sides.
Now turn it upside down and where “G” goes screw the support blocks “I” to the top. The silicon all the edges inside the box.
Screw “G” into place, screwing into support blocks.
Spray box with glue and cover in sub carpet. then cut hole in the carpet for the Speaker terminal cup and screw it into place.
Cooper
Australian Zeds
Hobart Tasmania Australia
3.0i 2001
Can you please post a couple of pix of the real completed box? Thanks.
@Susan - thanks for posting this up. I will add it to the article system as soon as I get chance to do so.
Hard top, are you able to link to the video?
I think he meant that he watched the progress of it, rather than there being an actual video of it happening ;) Unless I missed it of course!
hard top
Dutch Zeds
Netherlands
I'd be very interested in watching it!
Thanks
Hi David, Gaz is right, it was a progress thread with photos.
@Susan might post them up, If we ask her nicely......;)
Oh, and by the way, this is a teaser, one I nicked.....Shhhh
Susan
Central Coast
When completed I wasn't happy with the pulled look to the top, so I removed it and recovered the top giving it a more tailored look. This is the first sub box I have ever built. I made it out of cardboard first to get the pattern, then when I was happy with that I then cut the MDF. I found a lot of the how to build sub boxes videos on youtube to be very helpful on sealing it and covering it etc. to be honest I was surprised no one has made a how to build a sub box for the Z3, I looked high and low for a pattern for one... I then figured if I'm looking, no doubt someone else will be to, so I thought I'd put one together....I feel sure that you will improve on my pattern but at least you have a starting point..... enjoy :)
