Welcome aboard the Forum, you have arrived at the best Z Forum on the Web, help and advice always available here.
As our membership is Worldwide its a good idea to update your user details with your location and model of your car, it assists us in answering your questions.
You could also add a signature to show these detail so they appear in all your future posts.
Since your new to the Z I would suggest you bolster your tool box with a Code Scanner, you will save the cost of one the first time you need to use it. For a beginner I would reccomend a Creator 310+ or a Creator 410+ scanner, easy to use and will give you access to all the modules your likely to get codes for when things go wrong. Available on ebay and Amazon circa £50 + depending which one you go for.
