Yesterday I swapped the headlight bulbs on my newly acquired Z4 3.0L SI from the candles the car was supplied with to much brighter halogens. I knew from earlier discussions that it was going to be a fiddly job, and so it proved.
The near-side went relatively easily and painlessly - just awkward with the wheels on full left lock, but, at least being right handed, I managed to get everything back in place without mishap.
The off-side was a completely different story. I just couldn't get the cover back into the space that was marginally smaller than the cover itself. After a little colourful language and grazed knuckles I was contemplating taking the wheel off to give greater access. And therein lies the problem.
My small bottle jack was about 1" to big to get underneath the jacking point - Oh b***er.
After much more cursing and frustration, I managed to get the cover back on (hopefully without any additional muck on the seal. But, now i know I have a problem if I need to jack the car.
So, the questions:-
What do you guys out there use to jack up your car (am guessing similar issues on Z3s as Z4s)?
Any examples ?
Will a trolley jack go under the car?
If so, which do you rate?
Do you use a different point for jacking?
Do you run up onto blocks to give extra room?
So, the questions:-
Any examples ?
