heath
Hello all I have just about had enough of this car I seem to be just spending time & money on it & getting nowhere.
First off I have spent loads trying to sort the tramlining but it still tramlines (yes I know its got 18s on it & that will make it worse)
I then had a petrol leak which was the fuel filter. The ABS/ASC light kept coming on, had it plugged in it shown front n/s sensor so got that changed & still the ABS/ASC light comes on.
It seems low on power so had it checked to find the induction hose split & code PO340 which is the inlet cam sensor, just spent the afternoon changing the sensor & the induction hose then went for a short run checked the codes & still PO340 is showing (it was cleared before I went for a run) although it does go a little better that is probably down to the new induction hose.
I got my sensor from GSF car parts so should I email them to tell them the new sensor is faulty ?
Although the car seems to run ok apart from its still pretty gutless.
I have had the car 8 months & never had this many problems with any cars I have had before.
Its like everytime I do a job it dont fix the problem & I am now starting to lose my patience
Heath on Tapatalk
Heath on Tapatalk
