spotted on fb, usb sockets for bmw blanking plugs
http://nichemotoring.com/shop/usbaux-passthrough-button-blank
Now that's a good ideaspotted on fb, usb sockets for bmw blanking plugs
http://nichemotoring.com/shop/usbaux-passthrough-button-blankView attachment 23765
I bought one of these from Amazon to run an fm transmitter and I'm not sure it was a good idea for my application.
yes, if your device has a built in amp then yes it would require more oomph, not only is the voltage stepped down but the amps are also limited, 15 watts is too low, but i would have thought an FM transmitter is only about 100ma so is well within the capability's of a usb socket, did the device come with a cig socket adapter, there should be a sticker on the side showing the output of the adapter.I bought one of these from Amazon to run an fm transmitter and I'm not sure it was a good idea for my application.
I ran the fm transmitter via the cigarette lighter socket initially just to test it and it worked crystal clear as did the handsfree phone function.
I don't like having wires trailing about so opted to hard wire the supply via the usb sockets and because the voltage has been stepped down, not only is the music quality suffering, but the handsfree function is now useless.
It'll be getting removed and connected directly to the 12v me thinks. Yes/no ?
It did indeed come with an adapter @littlefeller. A dual usb outlet, 1amp and 2amp outlets.yes, if your device has a built in amp then yes it would require more oomph, not only is the voltage stepped down but the amps are also limited, 15 watts is too low, but i would have thought an FM transmitter is only about 100ma so is well within the capability's of a usb socket, did the device come with a cig socket adapter, there should be a sticker on the side showing the output of the adapter.
Hi, Ok got one of these, I had hoped to fit to a blanking switch but feel i wont be able to fix it securely enough, so looking to have the sockets just dangle down by the cargo net. Any suggestions on where to take power from?
I can help later with power supply Simon, busy till teatime.Hi, Ok got one of these, I had hoped to fit to a blanking switch but feel i wont be able to fix it securely enough, so looking to have the sockets just dangle down by the cargo net. Any suggestions on where to take power from?
many thanks
Hey mate, sorry late replying but this may be useful. I was watching someone fitting a dashcam on Youtube last week end and he quoted using an "Add-a-fuse" to connect a power supply, not knowing of these I had a look on eBay and found these. I didn't know which size fuses my car has so I bought one of each.Thanks Tony, Z Legend as usual
