Hi all, a few quick questions for you !! My 1997 2.8 has just failed its MOT on emissions. On inspection by the tester, he found that the wires from the post cat lambda sensor had been cut off, leaving the sensor itself as a blanking plug !!! When we investigated further, there was very little evidence of the route of the cable or where it connected back to the on-board computer. The pre cat sensor & its connection are in place & are easily visible. My questions are: Does my Z3 normally have 2 lambda sensors & if so, what's the cable route & where does it connect ??? I hope someone can help !!! Thanks in anticipation to any of you that knows the answer !!!
Rgds
Paul J
Rgds
Paul J
