well guys, another issue has popped up for me, I seem to have lost my low beams...
first off it was that they didn't turn off so I took out fuses 11 and 12 so as not to run the battery down, I went to scrap yard to pick up a new switch and put that in, there was no light now... I took apart my old switch and had a look at the pcb board and all was ok, springs on contacts were ok so put it back together and swapped it for the new one, same issue but with the lights off this time...
I checked for power on the block connectors for the lights and there was none, checked for power on fuses 11 and 12 and there was none, then checked power to fuse 25 and there was power, so, I am guessing there is a relay between fuse 25 and 11 and 12 that may be sticking... any ideas? thank you
