Hi Davie, welcome from me too here near Lincoln. Mine's a 2000 2.0 Auto. I haven't had many specific problems with mine in 5 years apart from Inlet camshaft sensor fault, engine goes into limp home mode (no power and EM light comes on) and the n/s door central locking solenoid packed up. Neither are big problems. Bearing in mind the younger of these cars will be 13 years old, there are bound to be some small issues but the build quality is/was good so not too much to worry about. Where are you located?
In Cheshire, Mac.If you've not driven a z3 before then try and get some miles in on a test drive or two. Maybe ask at the local BMW main dealer if they have any in and see what you think. The engines available make for very different drives.
Where in the world are you based?
So it's vital to loom for this but easily resolvable if it starts happening?Don't forget to check the condition of the rear subframe rivets in the trunk and under the rear end of the car. You're looking for subframe cracks or signs that the subframe is separating. There are lots of videos and threads outlining what to look for. The rivets can be seen from above by removing the carpeting from the trunk and almost near the front of the trunk floor maybe 6" from back of trunk there is a line of rivets you will be able to see running the entire width of the trunk. Check to see if any are pulled or showing signs of stress.. I would also check underneath to see if you see any cracks at the subframe mounts. The Z3's use e36 engine and drivetrain, but rear end is from an e30 to allow for the shorter wheelbase of the Z vs. e36.
My 2000 Z3 M-roadster is signing firstsigns of this pulling and i;ve just ordered a Randy Forbes subframe reinforcement kit. Shipped yesterday.
Cheers from up in CheshireWelcome from Portsmouth.
I'm about 30 but you're welcome to come down and see my Zed. Sorry though not till the weekend of the 28th March though as we'll be on hols....if anyone is in 15 miles of Crewe...
Cheers Mint...if I can hold off that long seen a v nice 2.2 2002 for about the right price although I have dawdled through the cheap period and now on the edge of silly money, this isn't too bad if I can get ... baring in mind the sound advice of members here.I'm about 30 but you're welcome to come down and see my Zed. Sorry though not till the weekend of the 28th March though as we'll be on hols.
