Magnetic stone guards warning!!
Daz3
Spilsby, Lincolnshire
Right I've had my stone guards on for a week, the car was clean before putting them on but upon washing it again today I found some small metal rust dots around them. This is probably more noticeable on my car being white but got me worried as the guards must have picked up the metal debris travelling about. I'm not so sure wether to use them anymore but I also don't want stone chips :(
bessieblue
chelmsford
Hi Daz3 is that around or behind the stone guards ? i'v had mine on for a while not noticed any problems.
swamper
Bacup
M
never thought of that...... but they would attract and hold on to metal ...shame you had to find out the hard way but well spotted ...good warning :-o
EnthuZiaZT
Heacham Norfolk
Z4 28i Msport
Yes, they do need taking off regularly, as they hold the water against the paintwork, I remove mine each time I put Mora in the garage whether I have washed her or not.
Mike
r37
SRP has very little cut, probobly surface rust, a common problem with white. iron x should cure it.
board
Staff member
M Roadster
Had mine on for about 10 years without any issues
hard top
Dutch Zeds
Netherlands
Me thinks bullcock personally.
Think about where you put them when you remove them from the car, work bench for example?
Or maybe Daz3 has sprayed the car with an acrylic polymer emulsion......... :D
Daz3
Well mine were brand new and stored on the fridge until I used them for the first time. Bullcock or not I had rust particles on my car so won't be using them again.
z3cade
Peterborough
I do notice grit collects behind mine and you can see an outline when you take them off sometimes.. So being magnetic they could pick up metal sworf..
Hardtop have you been putting them on your helmet? Looks abit rusty..
hard top
Dutch Zeds
Netherlands
^ Interesting, but I would still test them on the fridge first.................. :D
Z
zedonist
Daz,
Try 3M Ventureshield, i have been offered this when i have mine resprayed, looks good and effective on the old stone chips
Jamezee
Peak District
Had mine for years and never had a problem, just make sure you only put them on when the car is cleaned. I always make sure the area is polished and waxed too :)
B
bonzo
Gave Zelda wash today, and for the first time in 3 washes took off the stone guards and........................just lovely Montreal Blue metallic paint!
