Mechanic says it’s horrible 😢
MsMoneyPenny
Australian Zeds
Australia
1.9l
Hi Everyone
New to everything here….i just had our Z3 worked on for a Roadworthy certificate from our trusted mechanic and I asked if there was anything else he could see needed doing first up, his reply was ‘It’s horrible’! imaging the worst my heart sunk that it was a total lemon, but he further explained that it rode horribly (spine injury inducing) and I should consider fixing the suspension, unless I’m happy to drive it like an 18 year old. (?)
My son, the original purchaser, at 24 was very happy with the coilovers the last owner had fitted, but now I don’t know what to do? Do I need to replace back to original suspension or can the existing be adjusted for a better street ride? And how expensive is either option?
Any help and advice from the brains trust here welcome!!
ExMX5owner
Staff member
Australian Zeds
Queensland, Australia
But I,m guessing it did pass its RWC ?
ExMX5owner
Staff member
Australian Zeds
Here is mine, far from a smooth ride, make sure you have applied sufficient denture glue, your hearing aid is jammed in as far as it can go and your glasses are gaffer taped to your head, Then its bags of fun on the tight and twisties... A smooth ride is a perspective...:thumbsup:. It doesn't have the pony strengths to pull the skin off a rice pudding, but then, you dont have to slow down for anything other than a solid object...:whistle:. Tyres play a huge role in drive comfort, unless there are other issues. But the RWC pass suggests there are not other issues. Good news it got its RWC first hit..
MsMoneyPenny
Australian Zeds
Australia
1.9l
Oh I love it in white! Wheels look pretty magnificent too!
So sorry, it looks white on my phone...it's silver yes?
elevensies
North Lincolnshire
roadster 2.8 widebody
howdee, personally i dont like coilovers at all, never found anything that works in real road conditions better than stock.
unless your always on a track, why bother, if its for looks then go for it but deal with the harshness.
just enjoy the roads, and drive happy
MsMoneyPenny
Australian Zeds
Australia
1.9l
Thanks elevensies...no plan to be on a track, just cruising around enjoying life :)
Mike Fishwick
French Zeds
Daglan, France
I use Eibach front springs for a bit more negative camber (good on French country roads) with standard rears (for decent ground clearance when loaded) and Bilstin sprintline dampers. Ride and handling are excellent, and are far better than that of an Alpina Roadster S (their version of the Z4) which I experienced.
hawky443
You will probably find the bushes are away in the rear, I've found this is very common on the z3, subframe bushes and lower rear control arm bushes, well worth replacing.
andyglym
Post a full bush refresh I put the Bilstein B12 Pro Kit with Eibach Springs lowered by 30mm on mine, looked great and cornered well. However, it was a tad low for most UK roads so was a bit crashy at times, resolved by fitting a set of second hand Z3 Sport Springs that are only lowered by 15mm, night and day better and the stance still looks great.
