Metallic debris blown into exhaust manifold holes
Roman
I was wirebrushing some rust off the chassis and probably the drill blew some rust\metal particles inside of the exhaust manifold. Will it damage the engine? Should I vacuum the debris out from the exhaus manifold? Please help!
colb
Newport, South Wales,UK
By all means poke the vaccum cleaner in there and suck it out before you put it back together but whats got in there is going to get blown out when the engine runs, what little that got in thre shouldn't do any harm as it makes its way down the exhaust. You wouldn't want latge chunks getting clogged in the Cats so a good vaccum out is worth doing. In future plug the openings with some rag or tissue to avoid drbris falling in there.
