Jason Goldschmidt
- Feb 11, 2020
Hello all,
My zed has been giving me some trouble lately. The story goes...
-On a couple of occasions now, it has aggressively lost power and gone into limp mode. The engine idles VERY lumpy until restarted. I pulled the codes from it last time (with my cheapie code reader) and got P1170.
-Pulling coil packs one by one indicates that it appears to be running on two cylinders at that point (cylinders 2 and 3)! Some sort of problem with bank 2 cylinders?
-Reading the codes today with INPA showed nothing.
-If i switch the engine off and start again the issue always clears itself but will return almost immediately when the engine is revved.
-Unplugging the MAF sensor allows me to drive home.
-When I then plug the MAF in again and drive the car as usual, the issue might not return for weeks.
Whats going on here folks!!
Could it be a cracked manifold? I looked today but am not sure where they usually crack?
Thanks in advance all.
