TWO
Please can anyone advise on the strange wear pattern on the rear discs on my Z3, 2.2.......the same on both rear discs! :-s
As you can see the discs have worn from the inside of the diameter and on the reverse side have worn by a similar width but from the outside diameter of the disc........as if the calipers are twisting.
There was flexing of the caliper when I levered the spring clip out with a screw driver using the hub as a fulcrum, BUT all fixing points appear to be absolutely rigid. #:-s
I will clean every thing back to 'new' when I replace the pads; but in the meantime please can members advise on the cause............is it in any way effected by a leaking brake servor?
Many thanks
Many thanks
