Negative rear camber???
mwpe
Camberley
On standard suspension, very slight negative. The more you lower it the more negative you get.
Oldmsct
Delphi, Indiana
3.0I
Thanks ZG!!! To my knowledge it's never been lowered. It measures roughly 1/2' to 3/4' from bottom of tire at the ground contact point to the widest point of the top of the tire. Of course there is a bit more tire bulge at the bottom of the tire. I had the wheels aligned less than a year ago. It drives straight and corners like it's on rails. I'm not terribly concerned, just curious. You can actually see it in the pic at the left.:thankyou:
Remember that the Z4, unlike the Z3 does have rear suspension angle adjustment. My E85 has been lowered by approx. 3/4" but it doesn't show any negative camber. So long as you are happy with the handling and tyre wear no need to worry.
