Hi all,
I’ve recently bought a 1997 2.8 with around 78000 miles. I’ve wanted one since I started driving 5 years ago. So far it’s been more of a project than I had hoped…to sum up the car, on the way home I felt big vibrations on lift on the M25. When I looked, the rear left wheel was only held on with a few threads….
anyway, I have a few easier jobs on the go like diff oil/gearbox oil etc, I am an engine tech in F1 so am decent mechanically however I struggle to diagnose some of the cars quirks.
Most recently I have had some smoke on start up which I put down to early mornings in cold weather. Today the car really smelt on start up, more of oil than fuel. I have attached photos of the exhaust at start up and 10 minutes later once the fluid inside had burnt off. You can see a thick black smudge At the back of the pipe.
i have no cooling issues or coolant loss so hope it’s not a head gasket issue. I have a small leak from the rocker cover but not enough to noticeably lose oil.
has anyone had a head gasket blow or similar issue?
Many thanks,
Rob
Many thanks,
Rob
