just spent the last three hours replacing the rear discs and pads on my Zed, v happy now.
Thank you ShellyWell done
A much worthy job
Handbrake shoes were good.Did you do the handbrake soes while you were there?
Hi Tony,Only thing to do Tec is price the individual parts versus the complete arms. Then weigh up your time to do both jobs and make your choice. To change the complete arms needs 2 ball joint nuts, 2 rear mount bolts and the drop link nut all removing. To change the BBJ you need a press and a tool to press the new joint into the arm. The rear bush requires a large(ish) vice. Easy fix is complete arm. IMHO.
Priced up separate items, cost more. And cost of bead blasting wishbone and paint. I always go the extra mile and refurb completely, always have done.I replaced the whole arms, easiest option by far as already mentioned...
