New front strut brace designed for the Z3
Anthony Cherry
The front strut braces are complete. To match the rear strut braces
They cost a little more to make than I predicted but I'm really happy with the result. Powder coated in heat resistant paint in gunmetal paint. I will post the prices as soon as I have done the maths. But the should be between 120-150 with free delivery in the UK. I have 7 left from the first manufacture order. So pm me if you are interested.
Looks awesome as expected Anthony.. Will you be doing one for us M44 owners at a reasonable price?? JIM
And the E36 3 series 4 cylinder braces don't fit the Zeds.
You're quite right in saying that these don't fit the 6 cyl models Anthony, and that is because they're mounted higher, but with some modification they will fit. I fitted one on my car, primarily because it was considerably less expensive than the other types available.
Do you have a 4 cylinder
Hi Anthony, no my car is a 2.0 6 cyl. The strut brace fitted on the top strut mounting bolts ok after a small cut out for the earthing point. The problem was the extra height of the holes that the cross brace attached to. When I had finished fitting it instead of dropping the bonnet from a few inches as normal, some thing told me to lower it gently and that's when I found that the underside of the bonnet would have hit the cross brace mounting points. So I cut about 1" off the top of the brackets and re-drilled them, then screwed the adjustable ends further out to reach the new mounting holes.
