Hi, I bought my 2012 Z4 sDrive20i in 2018 with 37000 miles on the clock.
I have used it as my everyday drive since , pretty hassle free until last year.
I have fixed issues with bonnet cable and soft closing on boot.
I have still to work out how to sort an issue with the washer jets. The pump is ok and works when the key is inserted but stops working when the car moves off?
Currently just motd with 83000 miles and hitting a few snags Hence joining the forum.
Currently have a number of really frustrating issues all of which seem quite common with Z4 and are currently causing me real frustration. These culminated yesterday with the following predicament:
Roof mechanism had stopped working. water got into boot well and pump was wet for some time And looked pretty corroded. on pressing the roof opening switch the windows go down but the mechanism does not go any further. The alarm has been sounding intermittently for a while. I have presumed the pump is burned out and as off work yesterday had ordered a genuine bmw reconditioned pump and fitted it. This did not fix the issue. In doing this I also noticed the damp had caused significant corrosion to the red fuse box to the right of the battery. Nievely I disconnected the battery and took the fuse box out for cleaning down. As luck would have it rain started and we closed the boot lid down and I heard an ominous click. The soft lock of course hasnt activated but the boot is closed with no battery connection and no fuse box in place which of course means there is no full circuit.
I tried the green/grey wire trick last evening with no success.
the two doors are also open and of course won’t close.
Is there any other potential solution to open the boot from this position.
I am losing the will right now.
any advice would be really appreciated.
