Don't be so serious Tony.... My comment about it being an ugly slab, was a quote from some other Z3 owners on the options available for this trim. There used to be an Italian outlet for them which also was "flat" topped, but is no longer in production.
My point in making mine more like the M version is simply to have the two finishes complimentary, not an attempt to present it as a "wannabe" item. The M version is neat and it's what was produced for the Z3, so if you want a Z3 style finish, it seems quite straightforward to have an item "in tune" with the original design......Oh, and there are 5 less screws on the top of the bmtown item.... ie. the M version has 10 screws showing on top in the same configuration as my version. I consider my item at £45 incl postage to be more than I originally envisaged 7 months ago. After several attempts using plastics the quality vs lower cost just didn't work for me. Ultimately it came back to where I was late last year - aluminium. At £55 excl postage the bmtown option is an expensive "trinket".
