Hi All
I am getting overheating on my z3 and wondered if this is a known scenario;
Water level is stable and I believe I have successfully bled the system. Car drives normally and temperature comes up normally and settles at a normal temperature for a few miles, then starts rising up again.
I am able to stabilise the situation by putting the heater on full and speed 4 on the fan (not me as my temperature is rising fast!)
It all started when I overfilled the system and stupidly ran it for a few miles with a part undo filler cap to let a little water evaporate! It appeared to spit most of the contents out and took me ages to refill successfully without air.
Thought s are;
Pump must be pumping as putting the heater on it shows it is getting flow by the temperature coming off.
Assume it isn't the thermostatic fan as driving at a good speed on level ground it still overheats and the rad should be getting enough flow.
As I see the temperature stabilise for a little while I assume that shows the thermostat is working.
Could I have a radiator blockage reducing its efficiency? Or anything else?
Paul
Thought s are;
Paul
