Part Locator: Rear Light Housing Nut '97 Z3
JESFromASC
The plastic "nut" that should be holding the passenger side rear light assembly doesn't tighten down anymore.
Can you buy a new "nut" or is there a fix of some kind?
Can't be good for the bulbs being lose all the time.
Thanks
Stevo7682
Maybole , South Ayrshire
A quick look on real oem doesn't show it that way shows an M5 nut x8 ( must be inside the plastic wheel part of the bulbholder not available as separate part ) take the bulbholder out get an m5 nut and bolt see if same thredad as light unit mount points try running bolt into bulb holder and nut onto light threaded stud see whats worn .
Stephen.
spurs fan in a coupe
Thanks
You uk based? I can post you a cover with the knob attached
JESFromASC
No, I'm in the US.
Thanks for the offer though!
Think I'll go the Steveo7682 route and see if I can't create a fix for myself.
I haven't fully pulled it all apart to see my options.
