peteslag
When I picked up my 2004 Z4 3.0 the engine didn't feel very responsive and it used a considerable amount of oil. It had only done 51,000 miles so the oil consumption surprised me. After a bit of research the most likely culprit was the crank case vent valve (CCV). Apparently they get clogged up and cause excessive oil use. The procedure for replacing it looked painful so I resigned myself to regular oil top ups. I took the car to Cadwell on a track day and took some extra oil with me as I fully expected to have to top it up. Strangely, it didn't use a drop. Even more strangely it didn't use any oil for another 2 months after. The oil consumption came back but it was much less. I did another track day last year at Bedford and it hasn't had a top up ever since. I'm wondering if the previous owner drove the car slowly causing the CCV to clog? Maybe a good ragging is what it needed to free it up?
So, to sum up. If your zed uses a bit of oil drive it like you stole it!
