Plug I D please
si-forks
worcester
Not being one to sit around i thought i would fit a face lift trim in my 97 1.9 I've had it a while and it was about time i did . I was surprised how easy it was to fit (well easyish ). Anyway being an early base model it is lacking in equipment , so when it was apart I've found some unused plugs which I'm hoping someone can tell me what they are for? are the yellow ones heated seats ? The other is grey and I've no idea what its for?.The only real problem is the clock ,which is a different fitting to the early digital clock I've got the right plug from an old loom but not sure whether i can just cut the cars loom and wire on the new plug !
Si-forks on tapatalk
Titan
North North Yorkshire
sDrive35i
Re: Plug I D please
Yes
Illuminated gear knob
If there are only 2 wires you should be OK. IIRC the digi clocks are sensitive to polarity so make sure you get the +/- the right way round.
Brown is usually -ve.
HTH
Re: Plug I D please
Yes the yellow connectors are the heated seat switches.
Not sure on the other plug, can't quite make it out from the picture. Have you got a close up?
