- Nov 25, 2012
- Location
- Newport, South Wales,UK
- Model of Z
- Z3 M43 1.8 (1999) and Z4 E85 2.5 (2003)
2003 2.5 had a faily long trip out yesterday in the rain, parked on the drive which is a level surface and locked the car with the key remote. Short time later her in doors said car alarm is flashing the lights. Opened the car using the remote and checked the bonnet and boot and both doors were closed. Locked the car with the remote and within a short time it started flashing the lights again, no audible sound when this happens. Locked the car with the key which disabled the alarm and left it over night.
Today scanned it with BMW Scanner 1.4 after checking doors boot and bonnet were all secure. Locked with the remote and so far it didn't activate, with the alarm set I opened the boot with the key and the alarm flashed the indicators which I expected. Used the key remote to unlock and then locked it again. I did notice that when locking there was no flash of the indicators. Read the codes and the only code was me opening the boot with the key, it was listed as an historic code. I cleared the code. On relocking with the remote the indicators then flashed indicating it was locked. The Clowns nose light on the rear view mirror blinks away. Left it locked all day and so far no activations. I would add that I pulled the bonnet switch out and sprayed it with contact cleaner before leaving it on test. Will put it on INPA and have a closer look at the componant parts to see if anything is wrong with them. The absence of an audible alarm when activated needs looking at, its either duff or maybe coded out of use if thats possible, will have a look with the coding software that came with INPA.
Question is where is the siren unit, not had a good look for it yet, also where it the tilt sensor located
