Power source to the electric fuel pump
Davros
French Zeds
Midi-Pyrénées
3.0i Z3 Roadster
Hello Each,
Can anyone help me identify the power cable route to the fuel pump, please. Here's why: Many years ago I had a Triumph Stag; beautiful tourer and despite having an alarm system it got stolen. That was a long way back in the day when tracking gismos weren't readily available. So I looped in a cut out switch to the fuel pump and activated this whenever parked up. Fortunately it wasn't stolen again but I knew if it was it would only be a few hundred years away! And I hope to do something similar for the Z
The pump in under the carpet cut out behind the driver seat (RHD) passenger seat (LHD) and the main plug and wire are there, maybe a good place for a cut off switch, I assume from there it goes under the carpet or through the center console.
Davros
French Zeds
Midi-Pyrénées
3.0i Z3 Roadster
Thanks. I plan to move the hood power switch to the front consol, where it will be more readily accessible; so when it's moved that'll be a good location for the cut out.
