Powerflex bushes
Gwyndaf
Caernarfon
Z4M R and Z3M R
Soon going to be changing the bushes on the MR. Most opinion is the purple not the black, but what size would you guys recommend on the rear anti roll 14mm 16mm 17mm or 18mm, and what size on the front 23mm , 24mm, or 25mm , all sizes fit. Thanks.
Hugo
If its a M its probably the biggest size like a z3m is the biggest in the z3 range.
Hugo
I would fit the largest if it was me. Are you sure all sizes fit because on my 3.0 only one size did.
5harp3y
you need the bushes that are the same size as the ARB otherwise it'll be too tight or too loose
