Powerflex rear trailing arm bushings
Stormy_be
Belgian Zeds
Belgium, ieper
Z3 2.8 Roadster
Hello,
Just to make sure I've got the correct ones:
I want to order the rear beam bushes, would I need:
PFR5-309 (same as E36 compact)
or
PFR5-306 (same as E30)
Thanks, Koen
Stormy_be
Belgian Zeds
Belgium, ieper
Z3 2.8 Roadster
This is what I ordered for mine:
PFXPFR5-311
Powerflex Rear Beam Bush
Appears in Position 4 on Diagram
BMW Z3
Check the diagram here:
http://www.demon-tweeks.co.uk/motor...ar-beam-bush-appears-in-position-4-on-diagram
311 is indeed number 4.
I'm talking about number 5 on the diagram.
2 websites showed me the items for the Z3 as 306 (306G for the eccentric ones).
But 1 website showes that there would be a difference somehow (mentioning it should be 309 for the Z3 - same as the E36 compact).
....although I thought the E36 compact, the E30 and the Z3 all share the same rear axle.
Regards, Koen
I don't know about part number 5, but I suggest checking powerflex's website rather than others and email them to confirm.
On mine those were done years ago so will have to dig up the invoice.
