#ZedShed Project Jack Daw's 1997 1.9 Z3
Hot on the heels of the last project, we welcome in @Jack Daw and his very original 1997 1.9 Z3. Spent it's life on Jersey, so relatively low miles and almost zero corrosion underneath :thumbsup:
He got in touch with Lee to see if we could have a look over, and he joined us Saturday morning for the usual bacon powered project kick-off!
It's a simple remit, take it apart and replace what needs doing. No specific expectations of what needed doing, just leaving it to us. Jack stayed for the whole session, and got to see a little more going on that he'd expected - and a little quicker than he'd expected too :eek:
First job was to get it up on the axle stands, get the wheels off and then give it a good look over. Pretty much as expected it's in need of the "usual suspects", everything underneath looks original from the factory. As mentioned previously - apart from the mud in the arch liners, everything is lacking any kind of corrosion underneath. Almost a pleasure to strip down.
Once the rear wheel arch liners were removed it was pretty obvious that the beam bushes were on their way out. The rubber is coming away from the metal core, and there was a lot of play when a crow bar was levered against them. You can see this very clearly is in the difference from the first picture below, and the second.
As for the rest of the components it's the same picture, the shocks are weak, the drop links badly perished. Unusually the diff bush seemed really fresh, and no signs of deterioration. We've assembled a provisional list of things to replace, and then did this... :whistle:
We are claiming this as a record. Didn't time it, but around 1.5 hours to get it on the floor :D A real testament to the lack of corroded nuts 'n bolts underneath.
A few other pictures whilst we worked.
We get this every now and then, where the pin which holds the rear beam against the chassis unscrews, rather than the nut undoing. We kept winding and let the pin come out completely, which helps a little with the dropping process anyway. At the point it's in the picture below it should be the smooth part of the pin, not the thread showing. When we put the beam back on the pin will get a new dose of nylock on it.
We tend to strip the brakes off before dropping the subframe as it saves a bit of weight when lifting it up on to the workbench.
Talking of which, up on the bench ready to have the beam separated from the swing arms and diff.
We can now get a closer look at the beam bushes, and where the rubber is breaking away from the core.
Once we have all the new parts in stock we will crack on and get it put back together again.
PHILIP BAXTER
Cardiff
Z3 3.0i Roadster
Great work as always boys ( and Sam ). Jack, you will both notice and love the difference in your Zed.
Mine was like a new car.
Low Rider
Another excellent write up Gary.
The team have got dropping the rear end down to a fine art at 1.5 hours.
I'm sure @Jack Daw will be highly pleased with the end result as I am.
Antm72
South Yorkshire
Great practiced skills on show here the out and back in , in a day must be pretty close now...Another zed with a new lease of life:thumbsup:
2.2 & 3.0 Sport
Great job again guys, I love seeing this stuff going on:thumbsup:
Grumps
Forest Town, Mansfield
Z4 e85 2.5i
Love it. So good to see people enjoying helping others. You southern lot have a passion for these cars and it comes out in an abundance when you read these threads.
Jue and I are due down to visit @Lee and@Shortie_gal at some point. Don't know if I better hide Reggies keys for fear of it being stripped whilst I'm not looking! :nailbiting:
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
What a great write up :p
Well done to you all ;)
We did this with @windym just to prove we could do it :D Was a long day though.
Shopping list placed should be collecting tomorrow.
Front and rear shocks
Front and rear top mounts
Beam bush's
Front and rear drop links
Powerflex diff bush
Brembo discs and pads
New Aux belt
Plugs
Oils
all the filters.
Lots of goodies
DavidM
Ireland
Incredible work again from the experts - there are some lucky members on this Forum having access to such excellence!!
You know where we are, be a nice drive. I bet it will still be cheaper than a garage.
Grumps
Z4 e85 2.5i
Is a delivery and collection service available :D
In tact handbrake cables.......that must be a first?
What you going to do after lunch ? :ymdevil:=))=))
