I am just starting work on taking out the rear beam and suspension on Z3 I have looked at the pictures posted on here that I think Gaz documented showing all the bushes which are what I'm going to be replacing. What I'd like to ask is how many bolts hold the lower beam bush plate to the chassis I know there is a Alan key one and the main through bush bolt but I'm sure I can see a hexagon head bold next to the Alan key bolt. I've not got it up in the air yet to have a proper look but I've been sliding under every night this week spraying all said bolts with penatrating oil in the hopes that it will work its way into the threads a bit. So is it one or two bolts holding it is what I'd like to know thanks.
Roger
Roger
