Royalburger
- Aug 30, 2021
Hi does anyone know of any place within the Manchester or surrounding areas that would be able to fix/repair/replace the diff on my 2.8
Tia
Tia
I had the same a while back, It turned out to bre a failing diff bush, metal to metal causing the drone, and clunking because it was cactus. It looked OK however..Definitely the diff ..makes a continuous drone and clunk at times
