Stu1958
- Jun 14, 2018
Hi All
I had my 2005 E85 2.0 Z4 roof pump assembly refurbed and relocated to the boot.
So the problem is the roof closes every time ie comes out of the boot like a jack in the box no problem!
However, when i want to open the roof it unlatches from the screen then seems to stick.
It clears the roof just so the latches are not sticking but sticks just above the screen
If I help it with a push it continues and opens and latches down in the boot.
So as a test I swapped over each pair of hydraulic lines on the pump and reversed the motor connectors.
This way the roof pulls off the screen no problem at all but sticks coming out of the boot so the exact opposite of the above.
This proves to me that the rams are working fine in either direction as long as they are getting hydraulic pressure.
It also proves that for some reason the pump seems to be working far better in one direction than the other.
The motor seems to be turning equally well in either direction.
I recently acquired another refurbed pump and motor unit and this is acting in exactly the same way.
I am somewhat baffled!
Can anybody help?
Stu
Can anybody help?
Stu
