How To Guide Repair seized door mirror
Kendo
Scunthorpe
I realised one of my door mirrors had seized, I had a look around internet for possible repair solutions. Some replaced the mirror support with a fibre glass replacement. Some drilled out the base spindle and used a bolt. But I came up with this solution. The main issue seemed to be how to separate the mirror from the base once the spring and spindle had been removed. I used a dremel with a cutting disc and cut a slot in the base and mirror support as below. Using a screw driver as a wedge, open up the gap and the seized components can be parted. Cleaned up all the parts and rebuilt the door mirror using a new 13mm starlock washer.
Mirror base unit refurbished, note slot made by dremel
Completed door mirror re-assembled and greased.
Hence door mirror repaired for cost of one starlock washer.
BMBabe
Staff member
Community Admin
Aylesbury
Awesome write up :thumbsup:
Did you respray the mount yourself?
BMBabe
Staff member
Community Admin
Aylesbury
I did, removed all traces of old paint, applied acid etch primer first coat, then primer, then colour, then lacquer.
Cool nice work
Was it expensive to do?
Jack Ratt
The West Country
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
Nice one :thumbsup:
Thank you, I've been trying to separate my base from the stock for months now. I finally have it to the stage where I can attempt your solution and then find a replacement tube, spring keeper and a star washer. Anything I've missed?? JIM
Grumps
Forest Town, Mansfield
Z4 e85 2.5i
This could save a lot of people a lot of money. Excellent, thanks for sharing. :thumbsup:
Kendo
Scunthorpe
13mm star washers, plenty of suppliers on ebay
Kendo
Scunthorpe
You haven't missed anything, I cleaned all the parts and lightly sprayed with acid etch paint, applied a little grease. Then rebuilt.
Antm72
South Yorkshire
Great work. Managed to free mine off recently , comes in handy in the garage to fold them. A great job on the repair :thumbsup:
Thanks for the pics, one more seperation to make which is what you have done and I can get this put together if I can get the tube and retainer with star washer off eBay. It's important to me because it is the last piece Ashbandicoot donated to me prior to his passing so I really want to use it!! You've now made it possible!! JIM
PS or anyone have these parts laying around which I could buy?? JIM
Kendo
Scunthorpe
Pleased to be of assistance.....Kendo
mrscalex
Swindon & Swansea
Brilliant! I've been trying to progress past the seized stage for ages!
The people who sell the fibreglass replacement will sell you the spring, bolt, starloc washer & new mounting bolts separately. Just email and ask. The guy's name is Udo. http://www.spiegel-z3.de/index.html.
When I enquired a few months ago the price list was:
Complete replacement assembly with painted base 110€
Base painted/unpainted 41,90€/21,90€
Sleeve and starlock fixing 4,90€
Spring (stainless steel) 3,50€
Base to door securing screws M5 0,65€
Shipping to UK 16€
Thanks
Shipping to UK 16€
thanks for that info @mrscalex I'll give that a try. But I still can't seperate the base and the stalk! But now that I see how it goes together and there is a stub on the base I'll try the dremel cut and see if that helps! JIM
