#ZedShed Rosie the Turkish Green 2.8 Z3
This is the first build for the Zedshed team in its new home. With 60+ zeds built on axel stands this will be a treat for us using a lift.
Here is @LuvmyZ3.xxx Turkish Green 2.8 Z3. Tracey has nearly owned her from new. Starting at 2 years old and 3000 miles on the clock back in 1999 then 23 years later with 67,000 miles on the clock Tracy wants her restored to her former glory.
We had her collected from way up North on Friday and transported down to us.
At 25 years old in August the MOT process has finally caught up with Rosie. To be fair to the MOT guys they have been vary fair so far. So first thing to do was get her up on the ramp.
The colour code for those interested.
Next up is a selection of shots showing why it’s time to give her a front to back overhaul.
Full body shot
The main reason for the MOT fail. Rear trailing arms, Small holes we can repair with our Zinc process but multiple large holes and heavy corrosion on the upper arms make these arms way past their best.
Photos up front looking up.
An original BMW sticker on the shock
Slight gearbox weep, nothing a 50p seal can’t sort.
some more shots at the rear showing lots of heavy corrosion, luckily only on the bolted on items.
Rear exhaust section looking past it, always the first place they start blowing.
Standard condition for tank straps. Luckily we have an expert for these :)
Diff bush delaminating from the ring. Very common sight.
shot from the side just showing again the corrosion.
We also noticed a completely split CV boot. This we really don’t see much. Luckily BMW do repair kits so this is no big problem for us.
This may all look scary, nothing we haven’t seen before and nothing we cannot sort. The fun part begun shortly after doughnuts & Coffee. Because of some stubborn items this took us just over and hour to remove.
First item to remove was the exhaust. Nice clean headers on the engine. Gave us no issues. We also removed the propshaft at this stage
Gives us better view of everything.
It’s not a Z3 if you don’t cut bits off
Roll bar removed along with springs n brake lines
Support plate removed
Other plate removed, Now ready to drop
Down she comes.
First time this subframe has been removed since it was installed in 1997 looking all dusty with a side of light surface rust
We then removed the tank straps, old shocks and gave the underside a clean. Not bad at all for 25 years old
While we were on a roll we started stripping the front end out.
Dam reached photo limit.
Other side stripped
Parts begun to pile up quickly.
tool trolley getting solid use today.
So the car is 95% stripped. Just the last few items to remove up front. Stacked the parts onto a pallet ready for next weeks strip and made ready to head off to the powder coaters.
Good amount of work done today. Z4 was finished off and now drivable. Just needs some paint work done. Also the second Z3 stripped.
stay tuned for next week :D
Ian&Sue
North Yorkshire
1.9 Z3
Other side stripped
Really interesting as this car is aprox same age as ours. Been comparing your pics to some of our car but hard to tell how good/bad ours is as its all been waxoiled to try to fend of any further tinworm, looks as if its all origional & untouched though.
  • Agree
Reactions: Lee
andyglym
Other side stripped
Impressive stuff chaps :thumbsup:
Dunkelgrun
Maine
At first I thought “ what could that beautiful car possibly need?” Then I saw the shots of the corrosion. When everything is all cleaned up and has new bushings it will be like new again!
Mazza
Bognor Regis
You say the nicest things….💋😂😂
Stevo7682
Maybole , South Ayrshire
Nice to see a Turquoise Green zed at Zedshed hq a wide body into the bargain a rare beast its a colour that has really grown on me since we got our one .
Great work going on at the shed as usual.
The ramp must make that so much easier to do.
Some great pictures as always Lee will be looking forward to seeing the finished work.
Stephen.
Stephen.
Thanks for the nice words Steve, we've never had one in this colour before and its so pretty.
We've been lucky to get this oppertunity to take over this unit, it's only 2 miles away from me and on my way to and from work. The perks we get here are perfect, vapour blasting, grit blasting, Expert welders and a wealth of connections of the guys that have been here for years. Nice new chapter for us all, also worth baring in mind we all have normal 9-5 jobs ish so we only tend to play Fri/Saturdays.
I thought the same thing when the owner sent me the photos originally over a year ago. It lives in her garage but it is used for daily duties.
We had another good half day of progress. Lots of little jobs to sort and get all the metal work ready for powder coat.
First Up was the engine subframe and hubs. Last bolted on bits removed
Then it was position the engine cradle. Whoa she’s filthy.
soft ratchet strap supporting around the sump plus the chain on the engine lifting eye just in case.
then we can safely remove the engine subframe
leaving not much left.
we then made a cool discovery with the old springs. Original AC Schnitzer springs. Being replaced with OE ride height springs.
then we started stripping all the other bits making a box ready to drop into the coaters
beam bushes also removed, the biggest and move important bushes on the Z3.
arm tear down was basic because we’re having to source new ones.
the last week has been mad with delivery’s ready for the rebuild stage.
Jack Ratt
The West Country
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
Good work as always lads.
  • Thank You!
Reactions: Lee
Mazza
Bognor Regis
Had a trip up to the new Zed Empire today….only to drop off spares to Lee, but what a great set up they have :thumbsup:
Had to leave early to go to Brighton so will post some pics ( great Health and Safety ones!)
And an uninsured Polish driver hit my Z3 when I got back to Bognor !! :mad:
That car has got a hex on it Malc. Trust you’re ok? Is the car bad?
Bazza
The West Country
Verwood Dorset
Just goes to show even a well cared for low mileage low owners Zed needs a visit to the now famous ZedShed
For the magic to begin :thumbsup:
Nice little update with shiny bits.
Pile of rusty bits ready for powder coat
back all shiny
we also started prepping the underside, new tank straps on in the back ground
garage all tidy ready for Zedshed day.
