Rough Idle - Cold Start
Disca
Uxbridge, UK
New week, new posts trying to work out what bits and bobs are so I can decide when to resolve them!
When cold starting my 2.8 it tends to have a bit of a rough idle as the warming up process moves through its stages. As the revs start to drop down the engine has a couple of splutters, not stalling though, and then runs as normal. Then as it warms to normal idle level it may have a few more.
Doesn't feel like anything is out of the ordinary when driving, however I don't have a baseline to define what normal is at this point in time. I get the occasional minor shudder at traffic lights but nothing that moves the rev needle, which the cold start drops do.
mwpe
Camberley
I would recommend using a code reader before you start changing expensive parts.
Disca
Uxbridge, UK
Agreed, need to find one of those first!
Faheem
Leicester
I recommend this
https://www.amazon.co.uk/CAN-Bus-Trouble-Diagnose-Diagnostic-Scanner/dp/B001CBBY7O
along with this adapter
https://www.amazon.co.uk/OBD2-Femal...g_3?ie=UTF8&psc=1&refRID=T4HS3XSY6X03JZWQX2F0
Alternatively instead of buying an adapter - buy this - this is an airbag reset tool (which will prove to be very useful - and it will come with an adapter
http://www.ebay.co.uk/itm/Airbag-Re...767206?hash=item3f64a976a6:g:hVQAAOSwVL1V~o6x
But I had a similar issue and it turned out to be the camshaft position sensor. Do you find that your car is using excessive amounts of fuel?
Disca
Uxbridge, UK
I've only had the car a couple of weeks. So not to sure what is counted as excessive.
I've had an indicated average over the two weeks of 28.3 however I do alot of motorway driving and run the car as a daily, 70 miles a day.
Disca
Uxbridge, UK
Ordering the airbag reset tool as we speak also :) Thanks for the link
Check all the rubber hoses if you haven't already.
The 2.8 has a feed to the Idle control valve from the back of the boot hose. If there's a split it gets really lumpy.
Disca
Uxbridge, UK
Hi Lee
that means nothing to me :(
Hi Lee
I'll explain.
The air box that holds the air filter is attached to a rubber hose heading towards the inlet manifold. (Think its the only rubber component)
Check all around that rubber hose for cracks, specially under it.
Disca
Uxbridge, UK
Thank you for elaborating, I will have a check when home tonight, unless I find a spare 10 minutes at work later and it stops raining :)
Disca
Uxbridge, UK
Is it best to take the hose off to examine it properly or can you do it quite easily in situ?
Best to take it off. You can do this with just a flat blade screw driver. Very basic DIY, feel free the unplug the MAF sensor between the airbox and that rubber hose.
Disca
Uxbridge, UK
I've managed to take the cat off my motorbike and fit a new exhaust, so hopefully a flat blade screwdriver might be something I can manage :D
Using the bike to improve my capabilities however always scared of messing the car up lol. Think it might be a job for the weekend if im taking bits off!
This is less than a 5 min job. :)
roadvoyager1
Shotley Bridge
2.8ltr
Mine was only visible with the hose removed and concertina section expanded. So best to take it off and have a good look.
Disca
Uxbridge, UK
I'll see if I find time then, was more thinking about the light disappearing as I'm not back till 6:30 usually and then dinner etc get in the way.
  • Like
Reactions: Lee
Disca
Uxbridge, UK
Upon further inspection today, I have cracked hoses.
Now I need to work out the part numbers...
